12-13-2015 10:39 PM
12-14-2015
01:01 PM
- last edited on
11-04-2025
11:25 AM
by
Content Cleaner
Hi Ckt-builder25,
Which version(32 or 64 bits) of Multisim are you using? The next document tell us that Multisim 64 bits is not supported on Windows 10 of 64bits.
Did you already tried the suggestion they gave you? Try uninstalling the software, also run the CCleaner to erase all the files and then install again the SW
Regards.
12-14-2015 01:37 PM
12-14-2015 02:04 PM
Ckt-builder25
Where did you get Multisim? Did you install it using a CD or you downloaded from ni.com?
Regards
12-14-2015 02:15 PM
12-14-2015
04:06 PM
- last edited on
11-04-2025
11:26 AM
by
Content Cleaner
Maybe you will need to perform a force reinstall of the SW, follow the next link that tells you how to do it.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGwJCAW&l=en-US
Also, could be better if you try using another installer, may be you can download the installer from ni.com.
Regards.
12-14-2015 10:23 PM
12-14-2015 10:24 PM
12-15-2015
08:26 AM
- last edited on
11-04-2025
11:26 AM
by
Content Cleaner
Try downloading the files from ni.com. be sure that you search for the 32 bits version. I think that you can activate both version with the same serial number.
Can you please mark as an answer my first post?
Kudos welcome!! 🙂
11-01-2018 11:54 AM
Can i ask a question . How to uninstaller the multisim program ??
@Ckt-builder25
