Multisim and Ultiboard
The simulation results of second-order Butterworth low-pass filter are inconsistent with the theoretical values (when the frequency is equal to infini
The simulation results of second-order Butterworth low-pass filter are shown in the figure. Why can the amplitude only attenuate about 70db in the end? Shoe infinite in theory? Isuldn't it b it a matter of component parameter selection? Where do I modify component parameters?
(1,048 Views)
Привет, M!
Ничего не разобрал с картинки, кидайте файл разработки в формате "ms"
(1,027 Views)
Hi MHMT+,
Infinite attenuation can only be achieved at infinite frequency. The "roll-off rate" in the rejection band is almost flat so you might try sweeping up to TeraHertz or maybe even QuettaHertz.
When deviation from expected theoretical results manifest, the parameters of the operational amplifier are the first factors that you should consider. The important parameters are Gain-Bandwidth (Unity Gain Frequency) and Slew Rate rating among others. Click on the operational amplifier and open the Configuration Pane.
G. Goodwin
(998 Views)
