Multisim and Ultiboard
Three Phase Generator Machine Simulation Using Multisim
Is there a way to configure an INDUCTION_MACHINE_WOUND or INDUCTION_MACHINE_SQURREL_CAGE to simulate an electromechanical 3 phase generator?  I am seeking to simulate an actual low wattage generator in Multisim.
Thank you.
Message 1 of 20
(4,621 Views)
Вот такой подойдёт? Привет, коллега!
Симулировать надо минут 10-15..., пока синусоида не загенерируется.
Message 2 of 20
(4,581 Views)
Покопался в своих архивах, нашёл ещё две модели генераторов, файлы в формате "ms" не сохранились, к сожалению, но их можно восстановить...
Message 3 of 20
(4,518 Views)
Hello tipa,
     First, thank you for your submissions.  My apologies for not speaking or writing in Russian.  I am currently working with your Элмехген file.  I am going to analyze the output signals with a spectrum analyzer to see if there are harmonics of the outputs.  If possible, I would like to add a filter to the outputs to "clean up" the output waveforms.
Best Regards,
 rhcj
Message 4 of 20
(4,469 Views)
Вот ещё генератор с роторной обмоткой. Вместо R4,R5,R6 нужно поставить нелинейные резисторы, или другие компоненты снижающие ток в роторной обмотке возбуждения, дабы ограничить рост мощности и стабилизировать её.
Message 5 of 20
(4,507 Views)
Hello again tipa,  It is interesting that you can get 3 phases out of this machine, but I am looking to duplicate as closely as possible an actual 3 phase synchronous generator.  This machine has a DC input for the rotor and has access to the three phase windings.  At approximately 3000RPM, it will output a three phase voltage that is about 120V on each phase.  I know that I can use three AC_Power sources, but I was hoping that one of the electro mechanical devices would generate a voltage.
With kind regards,
rhcj
Message 6 of 20
(4,498 Views)
I read your message via a translator.  I now understand the need for nonlinear resistors to reduce the field winding to control and stabilize the operation.
Message 7 of 20
(4,493 Views)
-так я вам показал расчёт генераторов на 30 кВт с фазным напряжением 220 Вольт. Генераторы собраны на синхронных машинах с магнитами, модели с обмоткой возбуждения на якоре, к сожалению, Мультисим не предоставляет. Думаю, сделать такую модель можно на основе асинхронной машины, только добавить вместо"беличьего колеса" обмотку с двумя выводами...
Message 8 of 20
(4,479 Views)
Здоровья, коллега! Я давно уже не вижу никаких языковых препятствий при общении в интернете. У меня стоит браузер "Яндекс", который на все языки мира всё переводит автоматически, и довольно точно, особенно технические тексты. Я раньше много соприкасался с дизельгенераторными установками, которые используются в армии. От 2 кВт-бензиновых, до 500 МВт (на судовых  крейцкопферных, низкооборотистых дизелях). Если Вы знакомы с другими программами-симуляторами, то можно поискать в них прототип модели синхронного генератора с якорной обмоткой возбуждения, потом рассчитать параметры под ваши требования, а именно 3Х120 Вольт, 60 Герц. Можно в модель THREE_PHASE_WYE ввести зависимый источник, который будет добавлять амплитуду в каждую фазу, в зависимости от поступающего в него постоянного напряжения
Message 9 of 20
(4,461 Views)
Hello again,
                 Thank you for providing some information on your background.  I am an instructor at East Tennessee State University.  My motivation is to give the students some experience with the electro-mechanical features of Multisim and how they relate to the actual equipment we have in our lab.  I agree with you that simulation of three phase generators as a Multisim "Machine" is not going to work well, but I did have some success with other devices, such as a DC machines.  Attached are some experiments I ran with DC machines.
With kind regards,
rhcj
Message 10 of 20
(4,451 Views)
