 Hoonakwa
			Hoonakwa
			07-06-2006 09:12 AM
 kittmaster
			kittmaster
			07-15-2006 01:45 PM
07-18-2006 06:24 PM
Kittmaster,
I tried to draw a simple curcuit in mutisim. I had a AC power source a set of No contacts (space to close) and a relay with a latching set of contacts. Very basic. When I run multisim and press space the switch closes but the contact do not. I am not shure If I am doing something wrong or my settings are wrong. I had EB V5 years ago. I wish I could paste a copy of the image in this document to show you better but I dont have an FTP program to upload the image to the web. If you know where I could look at other small curcuits simular to sometning of this nature that wouls be great. A simple cicuit that would energize a relay and latch that relay on to keep a light on would be a good example.
Thanks for your help with this.
 TMP
			TMP
			07-19-2006 10:23 AM
The attach file contains a screen shot of the circuit I built as well as the circuit created in V9.
The relay used can be found in the Basic-->Basic virtual component bin.
When you double click on the relay, you have the option to define the current on/off. In this example, I set the current required to close the relay to be 10 mA and the off at 9mA.
07-19-2006 06:10 PM
 Euler's_Identit
			Euler's_Identit07-19-2006 10:06 PM
