Multisim and Ultiboard
Ultiboard Autorouter Bug?
Hi Skeatz,
I'm using NI Ultiboard Education v10.0.144. I'm able to find the corner mitering feature in my version and I have tried the example that you mentioned- GettingStarted.ewprj (GS3 tab). The autorouting result looks good after i applied corner mitering. I have change some setting at Design>Corner Mitering>Whole Design>Angle Maximum>95 degree (Instead of 45 or 135 degree). This is because a setting of 95 degree will mean that all angles less than 95 degree will be mitered to 135degree. You may take a look on the file that I upload after applying corner mitering.
best rgds,
pml
Message 11 of 12
(1,375 Views)
Hi PML,
Thanks for your input. Like you, I've tried corner mitering with different settings, including 95 degrees. What I found was that corner mitering can improve some of the tracks, but there are still a significant number of tracks with the 'jaggies' - circled in purple in the attached jpg file. I've yet to find a solution that works.
rgds,
skeatz
Message 12 of 12
(1,360 Views)
