11-07-2007 05:31 PM
11-08-2007 04:16 AM
11-08-2007 08:39 AM
Hi Chris, when you change the shortcut keys, or you customize your GUI, the new assignments should be saved on your User Configuration file. Before you reimage a computer, or move to another desktop, make a backup copy of it, then migrate or reimage and bring that file from your backup.
In Ultiboard, go to Options > Global Preferences, select the Paths tab, and you will see (and you can set also) where your user configuration file is saved, is under the User Settings section. Just go to that folder, locate that file and make a backup of it. Please note that the changes you made are only saved once you exit the software, so you have to exit Ultiboard before copying that file for backup purposes.
As a simple and quick guideline... go to Help > Ultiboard Help, and go to the Contents tab, the second entry from the bottom is called Archiving Data, check it out.
The same backup process applies for Multisim as well.
11-08-2007 08:42 AM
11-15-2007 08:45 AM - edited 11-15-2007 08:48 AM
I also use Ullticap and ultiboard since 1995, and I am completely agree.
Ultiboard is a good software, and better every year. But I can not understand why this king of software (some €...
), when an bug is found, or each month for example, NI should send a patch or upgrade.
I can not believe some bug staying one year or sometimes more. Why ?
Now Multisim. Are the developers use this software to develop a board? Ulticap was very simple and powerful. I ask a lot of basic improvement, but they come very slowly.
Just an example : When you create part in multisim. All pins can be created quickly, and with name 1,2,3... If you want to change the name of the pin, you only can do it with mouse. Select entire name and replace it. When you have 100 pins to change, it is very long... long... Mouse is good but keyboard is faster. And impossible to add shortcut here.
Same with ultiboard: when a bug is found, "it will be fixed in next release"... normally...
And us, why do we pay each year? We might wait "bugless" version.
I really think ultiboard is very good, but I think NI is not responsive enough
I really thing multisim (for schematic capture) could be good, but I thing NI should work on it and listen the user.
Have a good work
11-15-2007 11:36 AM
Dear users,
Hopefully the suggestions that Nestor has posted have proved useful (thanks Nestor).
Also, even though some of these postings are negative, we do appreciate the feedback, but I do think we need to address these comments as we are striving to make overall product improvements - A) foremost in the quality of the products and B) adding ease of use aspects that make your life as a design engineer easier.
Electronics Workbench has been around for a relatively long time, within that long history of time, National Instruments has only been at the healm for a few short years, and in fact, we only decided to integrate the NI-EWB group as part of National Instruments starting in January, 2007. With that decision we have made a concerted effort to make significant improvements - not only in the quality of the product - but through the methods by which we develop and test the product - and also by which we track and address product defects. We intend to keep moving forward with significant updates to our product so please keep the feedback coming.
Also, if any of the users out there that have posted requests have a 'laundry list' of specific items (some may have already been addressed), please forward them (with indications of priority) to myself or Nestor and these can thoroughly evaluated. Also, if you'd like to take up your questions offline, I'd be happy to address your feedback directly - please note my contact information below.
Best Regards,
Patrick Noonan
Business Development Manager
National Instruments - Electronics Workbench Group
50 Market St. 1-A
S. Portland, ME 04106
Email: patrick.noonan@ni.com
Tel. (207) 892-9130
Fax. (207) 892-9508
11-15-2007 11:56 AM
11-15-2007 01:34 PM
11-17-2007 12:07 PM
11-22-2007 03:36 PM
Hi Chris,
Happy Thanksgiving day...
What file are you copying?... it is indeed the User Configuration file the one that saves the toolbar information. However, please note that if the new computer monitor has a different screen resolution your toolbars might show up with a different space in between them and you might have to rearrange the location of the toolbars.... but the custom added buttons (or functions) should be there. Unless you added custom user-built button icons those are saved in another file.
In my case, my user config file according to the Options > Global Preferences > Paths tab is:
C:\Documents and Settings\nestor\Application Data\National Instruments\Circuit Design Suite\10.0\config\standard_ms_uni.ewcfg
It is similar for UItiboard just the filename changes to standard_ub_uni.ewcfg
I made some tests here and I can see it working fine... are you manually copying and backing up that file?
