 Stojan_Nikolic
			Stojan_Nikolic
			02-27-2012 09:51 AM
I have a problem I want to create a footprint for an AF transformer R/Z1606
A proper arrangement of the pins with the component wizard is impossible.
Is there an alternative to create footprints without the wizard, or maybe a possibility to arrange the pins as desired ?
 http://docs-europe.electrocomponents.com/webdocs/05a8/0900766b805a8d3e.pdf
 your sincerely,
 Stojan Nikolic
Solved! Go to Solution.
02-27-2012 12:44 PM
Hi Stojan,
You can create components without the Wizard - of course, then you have to do everything manually.
For more details, see the complete tutorial on the NI DevZone.
02-27-2012 01:16 PM
