Multisim and Ultiboard
Ultiboard - Place components on both layers
Aloha,
I'm trying to place through hole components on both sides of my board. When I swap a component from the top to the bottom layer, everything is garbled. I can't stack components on the same Z axis.
Any workaround?
Aya.
(3,418 Views)
Accepted by topic author Ayashi
Can you post up your layout if it's not confidential? Otherwise, can you create a service request on ni.com/support? We can help you figure out the problem. I tried swapping layers for a couple of components on my design and it worked fine.
Derek Z.
(3,385 Views)
