Multisim and Ultiboard
operational amplifier
Guys,
   I want to know what amplifier to choose in the analog library of Multisim circuit design. I'm just trying to simulate the following, it is pretty pretty simple.
Input1:A positive signal:12V
input2:it goes to ground.
vcc=10V
-vcc=-10V
And the output of this signal should be vo=Vcc for Vid>0 or vo=-Vcc for Vid<0, Vid=Vin-0.
But the amplifiers I choose they only give me zero as an answer.
(3,531 Views)
I`m sending the file using amplifier LM239J. But it is not working properly.
(3,530 Views)
(3,530 Views)
The LM239 has an open-collector output.  You need to pull the output up to +10V.  Also, +12V in on a part that has VCC set to +10V may work in the simulator but may break a real part if this circuit is ever assembled.
(3,514 Views)
