Multisim and Ultiboard
Ultiboard crashes with 3d, V14.1
I finally reached a point where I have some time to clean up my libraries and do a better representation of the 3d model of the components I created but now whenever I click on anything having to do with 3d, Ultiboard hangs briefly and then shuts down. I've tried the same thing on my windows 7 laptop and it doesn't have a problem so it is either a Windows 10 issue or something corrupted with this install. Any ideas on how to approach this?
I'm running:
Ultiboard Power Pro Edition
Application Version: 14.1.0 (14.1.31), Database version: 14.1.a
Build date: Monday, January 23, 2017, 9:22:28 PM
Processor: Intel Core i7-6700K CPU @ 4.00 GHz
Installed RAM: 64.0 GB
System type: 64-bit operating system, x64-based Processor
Windows 10 Pro
Version 1803
OS Build 17134.285
If any of that helps.
(3,120 Views)
I tried running 'repair' on the Power Pro installation and that didn't help.
(3,110 Views)
Can you tell us which steps you follow in order to reproduce this behavior?  You mentioned you cleaned some libraries, have you deleted any components related to Multisim?
Have you tried to reinstall the software in Windows 10?
Warm Regards,
Mario
(3,084 Views)
Ok, scenario #1:
I open the library manager. Click on a part I created in the past. I select 'Edit/properties'. I click on the 3D tab, Ultiboard shuts down.
Scenario #2:
I open a design, I click on 'Tools/View 3D'. Ultiboard shuts down.
Scenario #3:
I run the part wizard. I go through all the steps for creating a part. For this example I just click on 'next' for every prompt until I get to the end and I click 'finish'. It creates an 8 pin dip part. I then click on 'edit/properties' and when I click on '3d data', Ultiboard shuts down.
When I say 'shuts down' it just closes instantly.
I said I had time to start cleaning up my libraries, this was my first task. So I've done nothing else.
As I mentioned before I ran the 'repair' function which reinstalls much of the software. I haven't done a complete reinstall yet as that is a lot of work getting everything set back up again as it was before with all my settings, design rules, checks, etc. That's why I am asking for help here, so I can try some other thing before resorting to completely reinstalling the software.
(3,081 Views)
Accepted by jg_geadinc
Looks like it was a problem with my NVidia graphics driver. I noticed the updater application wasn't running in my system tray so I started it manually which it then reported there was an updated graphics driver available as of Oct. 4. I installed the new driver and tada! It now works without crashing.
(3,071 Views)
