Multisim and Ultiboard
Unable to establish OLE connection.
I am getting the same error as well, when I am using the following configuration:-
Multisim Power Pro Edition
V 10.0.144
Windows Vista Home Basic SP1
Any solutions?
Message Edited by Goldust on 12-05-2008 09:48 AM
Message 11 of 14
(2,106 Views)
Any solution at all? I desperately need to import netlist files into Multisim for one of my projects. Thanks in advance.
Message Edited by Goldust on 12-12-2008 09:40 PM
Message 12 of 14
(2,048 Views)
Hi Goldust,
The version you are running does not support Vista. You need to install the update that adds support for Windows Vista.
You can get the update through the Support and Update Utility, or from the website.
If you have the professional version, you can get the update from http://joule.ni.com/nidu/cds/view/p/id/896/lang/en
If you have the student/educational version, you can get the update from http://joule.ni.com/nidu/cds/view/p/id/931/lang/en
Once you have installed the update, you will need to reactivate the software.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
Message 13 of 14
(2,031 Views)
Thank you so much koekje. This solved my problem completely and rescued my project.
Message 14 of 14
(2,011 Views)
