Multisim and Ultiboard
Varying gain between Bode Plot and AC Sweep
Hello all, I've been running into an inconsistency between the bode plot and AC Sweep. If I'm not mistaken they should do the same thing.
I have a two stage band pass Butterworth filter with cutoff frequencies of 0.05 and 40 Hz.
Running a bode plot and AC analysis both show cutoff frequencies as desired. However, the bode plot has a gain in the band pass of 8dB, while the AC analysis has a band pass gain of 28 dB, What gives?
(1,868 Views)
Nevermind, found the source of discrepancy, it was the usage of the function generator by the AC Sweep while Bode plot used the AC source.
(1,856 Views)
