Multisim and Ultiboard
Virtual Diode
Is there a way to change the cutoff voltage of a virtual diode model in multisim v9?
Alan
(7,707 Views)
Which Version of Multisim do you have? This iformation Is necessary in order for us to give you a proper answer.
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(7,703 Views)
Version 9.1.221, it is the full version in the Education tier.
Alan
(7,699 Views)
Thanks, unfortunely, I have Version 10.0.1 so I don't think I can answer your question because of the differences and I don't have Version 9 to reference to.
Sorry, but Nestor, if he's here, will have to tackle this one.
Have a Nice Day
(7,696 Views)
(7,693 Views)
A diode doesn't have a defined "cut-off" parameter. It doesn't toggle ON/OFF states ideally like a switch
The forward bias equation is your Typical schtoky diode equation:
Id=Is*( e^(Vd/(n*vt)) -1)
Parameters in your control are Is (saturation current) and n(emission coefficient)
The cut-off voltage will typically be somewhere around 0.6-0.8V
Max
(7,690 Views)
