Multisim and Ultiboard
Waveshaping circuit using a 555 timer
I have been trying to replicate this circuit for the longest. I am trying to use a 555 timer as an Astable multivibrator with a one shot IC monostable circuit.  However, when I create the circuit and use different RC combinations I actually get the correct output from the timer, but it does not cause the one shot to go active and then I can immediately hook up a multisim clock to the one shot and the circuit works fine.  Can someone please take a look at the circuit I have designed and see where I went wrong? Please see attached multisim file.
(5,294 Views)
Accepted by topic author Ohms Law
Ohms Law,
Sorry for the delay on this - we've been busy at the EWB group.
Your circuit was very close!   I think by not having the CLR and A inputs wired, your circuit was having problems.   Likely the CLR pin was defaulting to a logic low (which would then force Q low and Q~ high) as indicated in the datasheet.
Here is the corrected circuit (note I increased the Capacitor to give a longer pulse time on Q / Q~ since the pulse period of the 555 timer was around 250ms).
When dealing with digital circuits, it is often convenient to hook up digital inputs to a SPDT interactive switch and to VCC (or whichever CMOS level the circuit is at) and ground as I have done here.   This gives you the ability to interactively control portions of the circuit for interactive testing...
19091i45DE207D56AC77B8
Patrick Noonan
Business Development Manager
National Instruments - Electronics Workbench Group
(5,110 Views)
32:
Would I do the same thing if I wanted to add a 121 one shot to the circuit that we have shown?  Oh yeah, that did work I just have to do my calculations to get the desired waveform.  Thank you a lot!
Lew
(5,100 Views)
