Multisim and Ultiboard
how to get optointerupter output
hi, i am using H21A1 optointerupter which is having 4 pins.(anode,cathode,emitter,collector).i am giving 5v supply to the anode through 220 ohm R and 5v to the collector through 10k ohm R.the cathode and emitter is made grounded.
Now i am observing the output between collector and GND.
            But the problem is i am getting 4.23 v when interupt is not present. it is fine. But when interupt is present it should give me arroud 1v.but it is giving 4.23v . so what is wrong with circuit.
(3,276 Views)
quary,
Sorry for the delay... can you please post circuit and I will take a look?
Patrick Noonan
Business Development Manager
National Instruments - Electronics Workbench Group
(3,105 Views)
