Multisim and Ultiboard
Where can I find IC 565 in NI Multisim?
Hello, I'm trying to recreate a circuit for an experiment in our "Communications" subject. There is a component called "IC 565" which I cannot find in the multisim. I'm a student but I'm using a Education NI Multisim (could be relevant, not sure). Where can I find "IC 565"?
(3,320 Views)
Hello, the IC you specified is not available in the master component library but if you have the Spice code you can create a component using the component wizard from Tools tab. ( the component will be added either in the user or corporate database)
(3,286 Views)
Where might I get the spice code for IC 565? The process in creating a custom component is too complicated for me to be honest. I'm not that far into circuitry.
(3,281 Views)
(3,271 Views)
