Multisim and Ultiboard
analitic response
I am an eletric engeneering student and I would like to use multisim 12 for my class exercises, so I would like to know if multisim can give analitic anwsers.
I mean: Can I assembly a circuit with a AC voltage source, for exemple, and then get the response voltage in some part of the circuit like a function (not a number or a graphic)??
or enter with a circuit schematic and no passiv componentes (like resistors and inductors) values and get a response in function of that variables (the passiv components values)???
Can give a hand with that?Cause it would be very helpfull for my studies!
(4,827 Views)
This is not possible, Multisim uses numerical techniques rather than analytical. You can see a lot of graphical reponse, like time response, FFT, Distortion and etc, but not their response functions.
Plínio Costa
Senior Techinical Support Engineer
National Instruments Brazil
(4,796 Views)
Ok, what about the transfer function (or network function)? I read something about multisim doing that, how does it work?
(4,791 Views)
Do you remember where you saw this information? Did it say about Multisim showing analytically the transfer function?
I'm going to search for this information.
Plínio Costa
(4,788 Views)
The transfer function of a linear system is measured through an AC analysis.  Any SPICE simulator will perform this analysis.  From the magnitude and phase response (or equivalently real and imaginary voltages), you have your complete transfer function in graphical form.  I typically export this into MATLAB for further analysis when needed.
There are many known methods that can take a graphical transfer function and estimate the poles/zeros.  Prony, Levinson-Durbin, etc.  See Modern Spectral Estimation by Kay.
Alternatively you can perform a pole-zero analysis and SPICE will derive the poles and zeros in the transfer function.  I assume it works by applying one of the common spectral estimation methods to an AC analysis.  You do have to manually filter out the poles at infinity, though.  It sounds like this is what you are after.
SPICE is a numerical simulation that solves ODEs using a variety of methods.  Multisim provides you with a way (in my opinion a very good way) of quickly designing or analyzing analog circuits provided you give it the right models.  What you are describing is performing a Laplace transform analysis on a circuit, which SPICE does not do as far as I understand it.  For simple circuits, this is easiest to do by hand, in MATLAB, or Mathematica.
-J
(4,786 Views)
syrop toolbox for MAPLE SOFTWARE
(4,666 Views)
