Multisim and Ultiboard
binary counter
hello!
   i don't understand why the count in this 4-bit binary counter jumps 7 (0111) ,in fact i think it cannot display 3 digits at the same time.i checked everything but it seems fine. what did i do wrong or didn't do?
(5,870 Views)
Hello ngogketrao,
the counter is working fine.
But what voltage across R1 do you expect, if more than 1 LED is on ?
I am working with :
UltiCap 2001 & UltiBoard 5.72 (for my daily work on XPpro-SP3, german)
Multisim Power Pro 10 (small & simple simulations)
Ultiboard Full 10 (no)
start looking for professional alternatives...
Sorry about my english!
(5,868 Views)
hi
  can you tell me what's wrong with my circuit? it is supposed to be a 8-bit PISO sift register.but the problem is that the diode doesn't display nothing.i have tried many different values for the resistors but none will do.
  thank you
(5,785 Views)
Tie the inhibit input low.
(5,771 Views)
i have tried that but it doesn't seem to work
(5,753 Views)
I took your circuit and simply tied the inhibit input low and it works perfectly. I have v10.0.1 of Multisim. Forgive me if you know this, but you must clock the circuit while the shift/load input is low and the S/R changes state on a low to high transition of the clock. Good luck!
(5,751 Views)
