Multisim and Ultiboard
bottom silkscreen text issue
Im having an issue where if i put my companies symbol (a combination of polygons and windows font text) on the bottom silk and export it, some of the letters do not export into the gerber file.  This issue doesnt occur on top silk.  Is this a known issue?
(4,150 Views)
Hi Kurt,
There has been an issue that you have described in Ultiboard where Windows font text on the bottom silk does not export correctly. We have fixed this for Ultiboard 10.1. Are you using Ultiboard 10.1 or something more recent?
Yi
Software Developer
National Instruments - Electronics Workbench Group
(4,146 Views)
I am using Ultiboard 10.0.1.
(4,124 Views)
This problem has been fixed and if you upgrade to v10.1, the problem will no longer be present. Fortunately, the file formats between the two versions are completely compatible.
Hope that helps.
Yi
Software Developer
(4,120 Views)
Don't have a current maintenance agreement to update 😞
(4,098 Views)
