Multisim and Ultiboard
can not simulate 555 Timer bistable mode
I m running multisim 13 and 14 pro edition I have tried to simulate a simple Bistable 555 timer circuit but when I reset the timer at PIN 4 the timer changes to off state temporarily and then gets to on, the same circuits works in all major simulation software except multisim, I ve tried set initial condition to zero but that did not solve the problem.
(5,035 Views)
Hello, I was looking at your circuit. i think that the biestable configuration was not the correct one. I did some changes to it and know I think it should work as you want. You can look at it on the following file. it is on Multisim 14. I do not know why I cannot upload .ms14 files so please just change the extension to .ms14 after downloading it,
I hope this helps!
(5,007 Views)
