Multisim and Ultiboard
multisim: remove footprint before transfer to layout
Is there a way to remove a footprint from a component (ie. make it virtual) in Multisim so that it is not forwarded to Ultiboard layout?
Some components are useful to the understanding of the circuit and simulation, but are not needed in the layout as they may be chassis mounted and not part of a circuit board.
(6,205 Views)
Accepted by topic author popman
Hi Popman,
Place the part on the workspace, double-click it then Edit Component db>>footprint. Select the footprint then click the Delete. Save this part to your database.
Tien P.
(6,191 Views)
Thank you so much, Tien. I just got around to trying that and it worked.
Garry
(6,133 Views)
I have the opposite problem: in version 13 (educational edition) all listed transformers are without footprint, nor they possibility to assigne one(???) . Any suggestions?
Zvonko
(5,061 Views)
