Multisim and Ultiboard
can't install multisim
I am new to multisim.after installing multisim I constructed a circuit.when i tried to run the circuit it shows access is denied to create some file named 02.cir in the temp folder.so i deleted some of the registry keys.now again i tried to install multisim but now the installer shows"The instruction at 0x01182a50 referenced memory at 0x00000000.The memory could not be read".please help me regarding this............
The screen shot is attached for your reference....
Message 1 of 9
(4,503 Views)
Hi Maaster,
Please have a look at this page and see if you can restore you registry:
http://forums.ni.com/t5/forums/replypage/board-id/370/message-id/10429
Tien P.
Message 2 of 9
(4,462 Views)
I can't access that link..........
note:there is no system restore point available.....
with regards,
maaster.
Message 3 of 9
(4,459 Views)
Hi maaster,
Have you tried repairing or re-installing Circuit Design Suite? This should repair your registry entries.
Message 4 of 9
(4,453 Views)
when i tried to install multisim ,the installer shows"The instruction at 0x01182a50 referenced memory at 0x00000000.The memory could not be read".regarding this i have attached a screen shot......
with regards,
maaster.
Message 5 of 9
(4,450 Views)
Try repairing Circuit Design Suite through Control Panel >> All Control Panel Items >>Programs and Features >> National Instruments (see attached screen shot). It will require your CD or downloaded install files to proceed. If this does not work then you could try the remove option. This should remove Circuit Design Suite and allow you to install it again.
Message 6 of 9
(4,444 Views)
I was not able to find anything of the type "national instruments".i was only able to find "Ni uninstaller".I attached a screen shot for reference.I think some registry files regarding national instruments may be missing.please say how to create those registries........
with regards,
maaster.
Message 7 of 9
(4,429 Views)
sorry i forgot to attach the screenshot.............
Message 8 of 9
(4,422 Views)
these were the errors i am getting when trying to install multisim.hope someone can help me regarding this........
ERRORS:
Structured Exception number 0xC0000005
Exception Report:
Exception code: C0000005 (ACCESS_VIOLATION)
Fault address:  02542A50 0001:00011A50 c:\temp\nii41F1.tmp
Registers:
EAX:00000000
EBX:00000000
ECX:0350E4EC
EDX:03680006
ESI:0350E4EC
EDI:00000190
CS:EIP:002302542A50
SS:ESP:002B0350E4A8 EBP:0350E528
DS:002B ES:002B FS:0053 GS:002B
Flags:00010246
Stack Trace
Address  Frame    LogicalAddr    Module    SymbolName + Offset
02542A50 0350E528 0001:00011A50 c:\temp\nii41F1.tmp DllUnregisterServer + 4477
02533DEC 0350EA18 0001:00002DEC c:\temp\nii41F1.tmp
025347BA 0350ED7C 0001:000037BA c:\temp\nii41F1.tmp
02534D75 0350F274 0001:00003D75 c:\temp\nii41F1.tmp
02535592 0350F5F4 0001:00004592 c:\temp\nii41F1.tmp
025419F7 0350F7F0 0001:000109F7 c:\temp\nii41F1.tmp DllUnregisterServer + 292
004A0CDB 0350F8C8 0001:0009FCDB F:\setup.exe
00474363 0350FBCC 0001:00073363 F:\setup.exe
00476A43 0350FCB8 0001:00075A43 F:\setup.exe
004EE3EC 0350FCCC 0001:000ED3EC F:\setup.exe
00523BDE 0350FCD4 0001:00122BDE F:\setup.exe
0040F641 0350FCE8 0001:0000E641 F:\setup.exe
0040F7FD 0350FD54 0001:0000E7FD F:\setup.exe
004F0EE8 0350FD80 0001:000EFEE8 F:\setup.exe
004F98A1 0350FDC8 0001:000F88A1 F:\setup.exe
004F9A84 0350FED8 0001:000F8A84 F:\setup.exe
006471EC 0350FF54 0001:002461EC F:\setup.exe NI_MetaToolbox_MetaOutput_GetSharedGlobalData + 935148
0050B18C 0350FF88 0001:0010A18C F:\setup.exe
7728E4A5 0350FF94 0001:0007E4A5 C:\Windows\syswow64\kernel32.dll BaseThreadInitThunk + 14
77C9CFED 0350FFD4 0001:0006CFED C:\Windows\SysWOW64\ntdll.dll RtlCreateUserProcess + 140
77C9D1FF 0350FFEC 0001:0006D1FF C:\Windows\SysWOW64\ntdll.dll RtlCreateProcessParameters + 78
Message 9 of 9
(4,417 Views)
