Multisim and Ultiboard
can't read old ddf-file
I have some old ddf-files of 10 years ago and I can't open them.
When I open an old .ddf I can see Ultiboard is starting and making a screen and then .....   the computer hangs.
The old .sch from Ulticap I can read by opening the .sch and save it as .utsch.
In Ultiboard there is no such a possibility because the files still end with .ddf.
Can I convert this .ddd-files?
Ptr
(5,361 Views)
Hello PtrZet,
Which new versions of Multisim and Ultiboard are you using now?
Regarding Ultiboard you should be able to open .ddf files coming from versions Ultiboard 4 & 5.
Which version were you using?
Older files that are coming from earlier versions should first be opened in Ultiboard 5 and saved in one of the supported formats.
More information can be found already on the following pages:
http://digital.ni.com/public.nsf/allkb/D23094994F003AB98625713200377B26?OpenDocument
http://digital.ni.com/public.nsf/allkb/BF3C6189ECE134D3862575280038D55E?OpenDocument
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,339 Views)
