Multisim and Ultiboard
cd4051 in multisim?
hi, im designing a circuit which requires the 4051 multiplexer/deplexer, however it doesnt seem to be modelled in multisim??  im a pretty basic user so i dont know what, if anything, i can do about this. any advice? thanks for your time.
Message 1 of 8
(10,440 Views)
If you are unable to find a component in Multisim, you can use the Creating a Custom Component in NI Multisim tutorial.  You will require the SPICE model from the manufacturer's website, if you would like a simulating component.
Hope this helps.
Sharanya R
Market Development Engineer
Message 2 of 8
(10,410 Views)
There are a few multiplexer models that you can use from our database (you can find 2, 4, and 8 channel selectors). A quick way to find these is to go Search... in the component selection screen and under function type mutiplexer. As for your specific component, you can try to find the SPICE model online, with this you can create a custom component.
Cheers,
Miguel V
Message 3 of 8
(10,409 Views)
thanks for the help, ill try the component wizard, could you tell me what a spice model is? or rather, what it looks like, i don't know if i'd know one if i saw one. is it a specific file, or code in text? sorry, this is my first time doing this so ive really got no idea what im doing
Message 4 of 8
(10,404 Views)
like, would the information in this datasheet http://www.fairchildsemi.com/ds/MM/MM74HC4051.pdf be enough to make a spice model for the component?
Message 5 of 8
(10,401 Views)
If you search MM74HC4051 SPICE model in the manufactuer's website or in a search engine you should be able to find something.  That is actually the datasheet that you have attached.  You might have to ask the manufacturer for the SPICE model if it not on the web.
Sharanya R
Message 6 of 8
(10,390 Views)
thanks for the advice ill try to get in touch with the manufacturer. just out of curiosity, g41040lt is written below the hcf4051b, what does this mean?
Message 7 of 8
(10,386 Views)
Can you explain what you mean by "g41040lt is written below the hcf4051b;" where do you see this?
Sharanya R
Message 8 of 8
(10,377 Views)
