Multisim and Ultiboard
change size on ruler bar
Hi all,
I set 'mm' for my measurement and I use ruler bar on Multisim and Ultiboard.  But on the ruler bars, it always shows only the reall numbers (no decimal).  It will help if it shows decimal number.  How can I change it?
thanks.
Kudos!
(4,470 Views)
The decimal in metric system are displayed only on a scale in the form of strokes. For this purpose it is necessary to increase scale of a workspace.
(4,463 Views)
Can you please tell me how do I change it in detail??
thanks.
(4,434 Views)
On both pictures the distance of 7 mm is displayed. However, on the second picture where the image has been increased (press F8), there were additional strokes. They allow to define, that the real distance makes 6,7 mm.
(4,429 Views)
I am sorry, I have inserted wrong pictures. I result the correct. It is necessary to consider, that the grid should be in metric units. Otherwise strokes on ruler bar will be incorrect.
(4,423 Views)
