Multisim and Ultiboard
audio transformer modelling
Hi, I would like to model a simple 10:1 audio transformer in Multisim, the LT700. The datasheet gives the following properties:
Inductance primary 2.25mH
Inductance secondary 550mH
DC Resistance primary 0.38 ohm
DC Resistance secondary 63.0 ohm
Primary turns 45
Secondary turns 420
But Multisim wants to know Le, Lm, E1, E2, V1, V2, or input / output voltages. I can't find any explanation of these parameters in the manuals (the manuals just give fairly useless definitions of transformers). I haven't done any spice modelling before, so how do I produce this transformer?
(5,284 Views)
Hello Graham,
I believe that these elements are as follows:
Le - primary inductance
Lm - secondary inductance
Rp - primary resistance
Rs - secondary resistance
As for the rest, I think this forum may help you:
http://forums.ni.com/t5/Circuit-Design-Suite-Multisim/How-does-the-n-turns-ratio-works-in-Multisim-1...
Let us know how you get on.
Kind Regards,
Michael S.
NI UK & Ireland
(5,200 Views)
