Multisim and Ultiboard
constant voltage constant current
             i tried to simulate a adjustable current and ajustable voltage power supply in the lm317 datasheet the specifications are vout=1.2v to 30v  iout =0A to 5A the problem is that when i turn the voltage pot to go 1.2v  the vout is 9.804v is the minimum output voltage it simulates. can someone have a clue and can help  with this
 this are the files:
(6,213 Views)
Hi kind2011,
I suppose you get the diagram from the LM317 datasheet (Page 21).
http://www.ti.com/lit/ds/symlink/lm117.pdf
I think we have a wrong connection in the ADJ LM317 pin, I recommend you to check the connections in this part of the circuit. Maybe you must to change the positive and negative voltage to LM301A supply source, because you need a little bit more voltage that you want to get in the output, those supply voltages could be -5V and 31V...
Hope this information helps...
Omar I.
(6,185 Views)
