Multisim and Ultiboard
copper area connected to wrong net gives no DRC error
I have a couple small copper areas connected to differents nets in my UB11 design.  I noticed that no DRC error is detected when the copper area assigned net does not match the net name it is connected to.  If voiding is on it clears it away, but if voiding is off it connects with no DRC error.
I assume that should be a considered a bug.
(3,629 Views)
You are assured, what at you Copper Area? If it is Poligon, he should be selected and chosen Design>> Shape to Area. After that to appoint a net to which should connect Copper Area (Copper Area Properties>>Copper Area>>Connected to net).
(3,621 Views)
Yes the area is assigned to the net.  The problem is no DRC error is generated if it is assigned to a net other than the one it is connected to.
(3,614 Views)
I had problems with Cooper Area while I have not put updating of 11 versions. You have updated the program?
(3,607 Views)
