Multisim and Ultiboard
custom component pads corrupted
Hi, when I try and create a custom through hole part in ultiboard, the pads created have 2 inners - in all the ready created components through holes just have top and bottom - i don't know what these inners are.
I am using the part wizard which seems to work fine but when it comes to the part where i re-arrange and edit the pads these two inners appear in the pad properties, like so -
copper top
copper inner 1
copper inner 2
copper bottom
 I can't seem to get the right settings with these inners...  How can i get teh part to create just top and bottom copper for through hole parts and no inners?
(5,494 Views)
Accepted by pgo48
Hi there,
For complex PCB design, usually we have multiple inner layers to separate the Signal, Analog GND, Digital GND,different power signals etc. You can find this typical complex PCB design in DSP board for example.
In your situation, you can just set the layer pairs to 1 in The PCB Properties.
Double click the blank space in your work area or just click Options==> PCB Properties==>Copper layers
Hope it helps!
Chen_T
(5,482 Views)
