Multisim and Ultiboard
dc/dc converter + schematics
Hi !
Im building one DC/DC converter.
There are two versions. One with LEM and one without.
I draw all the parts in multisim and i will post them if someone wants to.
The problem is second schematics is LEM (missing ) :
http://oi45.tinypic.com/143i92w.jpg
On my first schematics we didn't use this par so the schematics is simpler.
http://oi48.tinypic.com/v98k0.jpg
Question:
Till i find a way to simulate LEM...how can i draw shunt connections ( schematics without LEM ) ?
Huby
(5,348 Views)
btw. there is one error.
40160 should be switched with MC14016.
(5,336 Views)
could you please explain what you mean with LEM?
What do you want to do right now? The way I understand it, you want to create a Dummy Part that you can use until you've found a better one. You can always do this using the component Wizard, but I figure you already know that. Maybe if you could explain what you would like to do a little more precise, I could find out for you.
Remember Cunningham's Law
(5,329 Views)
:-). LEM is something like SHUNT.
http://datasheet.octopart.com/HXS-50-NP-LEM-datasheet-146478.pdf
This is the model from one college who design this:
http://oi47.tinypic.com/2hrz9d3.jpg
Is this OK ?
Btw. can you help me out how to draw a SHUNT ?
I can use the older schematics to see how it works without LEM.
Huby
(5,317 Views)
I too just want that schematics, i tried on my own and couldn't finish that successfuly....im trying for 230v output by gvng 12v as input,
pls,help me out regarding this.....
(4,912 Views)
