Multisim and Ultiboard
independent current source with set of conditional equations
hello,
I'm trying to build this customized block. it has a bunch of fixed value elements (2 resistors and 2 capacitors) and a current source. the current source needs to have a value that's based on a conditional expression expression:
Id = something; for Vgs < something, Vds < something
      something else; for Vgs < something, Vds > something
      something else; for Vgs > something
I have the equations and I have all of the parameters, but I have no idea how to implement the conditional statements for the current source. I'm not even sure where to start. thank you very much for any help.
r.
(5,626 Views)
rob_xx17,
These are Analog Behavioral Model sources, for current, ABM_Current, and also ABM_Voltage for voltage.   They are very useful to set up a series of conditions (relative to other values within the circuit) to generate appropriate controlled current and voltages.
The ABM sources can be found in Master Database -> Sources -> CONTROLLED_CURRENT_SOURCES  (or CONTROLLED_VOLTAGE_SOURCES).
Here is an example of using them with a nested if/then conditional.
In this example I1 is depended on the voltage at net(1) - which is simply V1.
So in this example, for I1 you have 3 states (dependent on V1):
a) V1 > 4V, I1 = 1 (Amp)
b) V1 <= 2.5V, I1 = 0 (Amp)
c) V1 greater than 2.5V and 4V or less (inclusive), I1 = 0.1 * V1 (Amp)
Here is a look at the behavior of I1 as V1 varies from 0 - 5V and back from 5 to 0....
To specify a single ended voltage referenced to ground net(0), you just specify V(netname).
To specify a differential voltage, you would state V(net, net2)...
Pat Noonan
(5,625 Views)
