 anipros
			anipros
			10-25-2008 01:28 PM
I am using UB 10.1.197 on a machine running Vista Ultimate.
When I am in the footprint edit mode, selecting a pin, then double clicking it for its properties will cause Ultiboard to crash, everytime.
Selecting the pin, then right clicking it, then selecting properties, opens the properties screen as it should.
MET
 Fernando_D
			Fernando_D
			10-27-2008 11:43 AM
Does the crash happen with a particular footprint? If this happens with a custom footprint please attach it here so that we can run some tests.
 jackinnj
			jackinnj
			10-28-2008 01:30 PM
10-29-2008 11:23 AM
No, it is not a specific footprint. If I go to the master database and copy a footprint to the user database then edit it, double clicking on any pad will cause Ultiboard to crash. It doesnt seem to be related to just the pads. Double clicking on outline lines on the silkscreen have the same effect.
MET
 Fernando_D
			Fernando_D
			10-30-2008 05:05 PM
Hello Jackinnj,
Are you also using Ultiboard 10.1.197 (Help>>About) on Windows Vista Ultimate?
01-07-2009 03:08 PM
My Ultiboard main program has not crashed since I installed the new update. I am using Vista Ultimate. Thank you.
However, double clicking on items while in the footprint edit mode will still cause a crash everytime.
Tools, Database, Database Manager, User Database, Select a part, Click edit, Click Select Tool, Double click on a pad- instant crash NI Circuit Design Suite 10.1 has stopped working message.
Does not matter whether the part was created new or copied from the Master Data Base. Double clicking on the ? or other items will also cause the crash.
And just as before, right clicking and selecting properties works fine and is the temporary solution.
Michael
01-09-2009 09:56 AM
Hi Michael,
This is a known issue that has been fixed for our next update (date TBA).
In the meantime, you should be able to select and edit footprints without clicking on the select icon.
