Multisim and Ultiboard
graph time size wrong
hi im using the transient analysis tool of multisim 12 i put time stop to .1 seg and add the voltages nets i want to display but the graph time axis is -1, 0, 1
and nothing is displayed why i am expecting is a time axis from 0 to .1seg. even if i go to properites of grap and right axis tab and set 0 to .1 and apply nothings happens, im desesperated:manfrustrated:, please help
(4,547 Views)
also i export the graph to excel sheet and only shows to time steps, i expect almost 10 steps to end in 1e-1, attached is the sheet in excel please help,thanks
(4,543 Views)
Hello!
I’ve tried to make the same kind of analysis as you are, but I could not replicate your problem. I’ll show you the steps I followed and the results I got, maybe you are missing some of the configuration steps.
1)      I built a simple integrator circuit
2)      I selected Simulate>>Analysis>>Transient Analysis
3)      In the Analysis Parameters Tab of the Transient Analysis, I typed the following parameters:
-          End time: 0.2s (in your case this should be 0.1s)
-          Minimum number of time points: 20 (you could specify the 10 points you wanted)
4)      In the Output tab, I chose the parameters I wanted to see
5)      Click on Simulate button
6)      Here’s the output I got
7)      If I export it to Excel, these are the results
I hope this is useful!
José Alberto G.
ELP Support Engineer
www.ni.com/soporte
(4,497 Views)
