Multisim and Ultiboard
doAnalyses: Iteration limit reached Error & time step too small
Hello everyone
i want simulation  Sallen-Key Second-Order Low-Pass Filter
0.25Hz
how to solve the error
thanks
(13,028 Views)
This seems to do with the opamp component that you chose to use. Beside the fact that the component is not a single rail supply unit, switching it out for a simple ad opamp or a virtual opamp seems to make your circuit run properly.
Kind regards,
Miguel V
(13,018 Views)
Miguel_V 已寫:
Kind regards,
Thank you for response
but my circuit use the opa
so i how to solve the error?
(13,012 Views)
Hey,
So I found out the problem with the model. Seems that when this instrument you created was made, the supply pins were switched. So you created a model with the -VS pin to be the input for positive voltage and the +VS pin with the input for the negative voltage. I would recommend double clicking on the model, Value » Edit component in DB » Symbol » Edit and change the position of VS+ and VS-. Or simply to test your circuit switch the supply and ground.
Cheers,
Miguel V
(12,997 Views)
Miguel_V 已寫:
Hey,
Cheers,
HI
thanks you respond
i use TLC2274MN spice model with work
(12,955 Views)
