Multisim and Ultiboard
hole in powerplane V12
First of all: I can not select V12 when reporting a bug....
When I place a copper Polygon and open the proderties windows, I select "Not connected to outer edge" a rectangle is cut out in my plane.... ??..
When I uncheck it, my plane is filled again... but now I have to manually remove all islands..
Chris.
(3,360 Views)
Hello Chris,
I tried to reproduce your Ultiboard problem but that didn't work.
To reproduce your problem i want to see your project.
Could you post your Ultiboard project on this forum?
Kind regards,
Corné Westeneng
Applications Engineering
(3,330 Views)
