Multisim and Ultiboard
how i can use 3 terminal feed through capacitors in multisim?
dear all,
is there any method by which i can use 3 terminal feed through capacitors in multisim? is there any library or something else? i have found tdk 3 terminal capacitors but didn't find any library in multisim...
http://www.tdk-components.de/en/whats-new/press-releases/archive.php?we_objectID=2626
best regards..
(4,296 Views)
Hi Asim63,
Multisim doesn't have this component in the database and you have to create it.  Here is the component creation tutorial:
http://www.ni.com/white-paper/3173/en
I couldn't find a datasheet for this component and I am not sure how it works.  If you don't need this part for simulation, select "layout only" when you go through the component wizard in Multisim.  If you want to simulate this part, you need a SPICE model.  Have a look at this document to create your own SPICE model.
 https://decibel.ni.com/content/docs/DOC-16246
Tien P.
(4,277 Views)
