Multisim and Ultiboard
how to install NI circuit design suit 10.1.1
hi...
i'm unable to uninstall NI circuit design suit 10.1.1,
i got some problem when i'm installing the software, after that i removed back up files from program files and uninstalled from
control panel (add / remove programs), and i did every thing....but i'm unable o uninstall completely....
so please help me how to unstall the software...
so that i will install software again...
(5,285 Views)
Accepted by ellendula
 What are the problems you are facing. And when did you face that problem.
 Please tell us the error message you are getting.
Hardik
(5,271 Views)
hello...
thanks for ur reply...
i'm facing problem ...like initially i installed NI design circuit suit (product evaluation).....so it doesn't installed properly...
after that i removed the back up files in C:/program file .....i removed whatever the files related to NI in the system...
and i tried to re install again .....then i'm getting error like
"Higher version of this product is installed in ur computer" but i removed completely even then i'm getting the same error and
i'm unable to install...
so please help me how to overcome my problem......
(5,265 Views)
There is a software called msiblast.exe. It removes all NI products installed on the computer.
You can use that software to remove all NI software from your computer and then try reinstalling the software.
I hope that will help you in installing the software.
Hardik
(5,261 Views)
hi...
thanks alot for ur information...
it worked well....
know i able to intsall the software....
thank u so much
(5,248 Views)
