Multisim and Ultiboard
looking for buck converter ic
i am looking for buck converter ic simulation model. that buck converter specification is 265V input and 24V, 3.4A output. anyone can give solution for this qustion?
Pradeep Kumar Achu
(4,321 Views)
In Multisim 12.0 we have a Buck Converter component available, in the Miscellaneous Group, under the Buck_Converter Family.
If you double-click on the component, and select the Value tab, you have the option of specifiying the filter inductance, filter inductor ESR, and switching frequency.
Sharanya R
Market Development Engineer
(3,352 Views)
I want to build a bulk convarter with an
input volt= 24v
output volt= 5v
current in the load=1amp
Fsw= 100KHz
Irpp=200mA
Vrpp=5mV
 what value of L AND C , R can i use, becuase i made some calculation already for the values and i still get a different volt at my output when i simulate.
which IC (containing PWM and driver) can i use.
 or better whats your advice on the IC
(3,289 Views)
