10-08-2009 04:57 AM
09-05-2012 09:07 AM - edited 09-05-2012 09:08 AM
In Multisim 12.0 we have a Buck Converter component available, in the Miscellaneous Group, under the Buck_Converter Family.
If you double-click on the component, and select the Value tab, you have the option of specifiying the filter inductance, filter inductor ESR, and switching frequency.
09-27-2012 08:01 AM
I want to build a bulk convarter with an
input volt= 24v
output volt= 5v
current in the load=1amp
Fsw= 100KHz
Irpp=200mA
Vrpp=5mV
what value of L AND C , R can i use, becuase i made some calculation already for the values and i still get a different volt at my output when i simulate.
which IC (containing PWM and driver) can i use.
or better whats your advice on the IC
