Multisim and Ultiboard
master database component prefix
Many of the sub-families of the Transistor Group have the component prefix set to U instead of Q.  In a few cases (e.g. transistor arrays) this may be reasonable, but for most of the families, it's just plain against reason 🙂
Can some kind soul get this fixed please?  Oh yes this is Multisim 10.1.1
Dave
(5,526 Views)
you can't edit master database, you have to change refdes manually per part
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(5,489 Views)
Yes, that's why I'm griping!   If I could edit I would :-(.  I know I can change the **** prefix every time, and it's a pain in the proverbial.
D.
(5,485 Views)
I here you, but its never going to happen.   I would suggest you take the time to build your own corp library and port over all the parts from the master you need.  Really no other way around it, unless they make this a "feature".  But I'm doubting it.
(5,483 Views)
What! You're syaing they'll never  fix a *blatant* and  major useability bug?   That's unforgiveable.   Grrrr.
D.
(5,480 Views)
Accepted by david_c_partridge
Hi David,
I've taken a look at the database, and you are correct that some of the families in the Transistors group should have 'Q' for default RefDes prefix. I've entered a bug (115426) so that this will be fixed in a future release.
For the issue of not being able to edit the Master Database, kittmaster is correct that we will likely never allow customers to edit the master database directly. That said, I do agree that sometimes it would be nice to have this ability, and (as one of the developers of the product) I would like to see this become a non-issue in a future release.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(5,442 Views)
Thank you very much.
D.
(5,432 Views)
