Multisim and Ultiboard
max7219
when i simmulate the Max7219 i got the errors like this
------ Checking SPICE netlist - Friday, November 14, 2014, 5:24:10 PM ------
SPICE Netlist Error in schematic RefDes 'u1', element 'tu1': Unable to parse parameter name
SPICE Netlist Error in schematic RefDes 'u2', element 'a1': Digital and analog pins are connected on node '$19'.
SPICE Netlist Error in schematic RefDes 'u2', element 'a1': Due to errors, the component 'a1:xu2' has been omitted from the simulation
======= SPICE Netlist check completed, 3 error(s), 0 warning(s) =======
can u help me to solve the problem plzzzzzzz
(5,664 Views)
The Multisim database does not contain the MAX7219, are you using a custom component? If so can you attach your circuit file and / or the model you are using so we can take a look?
Jeff
(4,872 Views)
