 kvn
			kvn
			11-14-2014 10:16 AM
I am not able to find ic um66 or LM386 which has similar properties , is there any ic availabe in multisim having similar properties?
		06-29-2015
		10:59 AM
 - last edited on
		10-09-2025
		03:11 PM
 by
		 Content Cleaner
			Content Cleaner
Hi kvn,
A similar part is the LM3875TF/NOPB, which is in the Multisim database in the AUDIO_AMPFLIER family under the Analog group, you can use that if it fits your needs. Otherwise you may be able to find a SPICE model for the LM386 by searching Google and from there you can create a custom Multisim component. You can use this tutorial as a guide: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YH5fCAG&l=en-US
Hope that helps,
Jeff
