Multisim and Ultiboard
maxim-ic custom component help
Hello!
I am trying to add this component from maxim-ic using custom component from this script and I feel I set it all up correctly. However, I am getting a 'Timestep too small' error at runtime. If anyone has any insight or similair experience with help to a solution, I would be very appreciative.
-I attached the circuit I built from the datasheet, but FYI the chip by returned the error before I added all this, and I cant be certain the schematic is correct.
(3,658 Views)
Hello bazcheck,
Is this still a running issue?
The link beneath "this script" doesn't seem to work.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,205 Views)
