Multisim and Ultiboard
menu bar disappeared
Today, all of a sudden, the main menu bar in Multisim disappeared (see attached). I tried a repair install, but to no avail. Am I missing a setting somewhere?
I appreciate your help.
Howard
(4,052 Views)
It is very likely that the user configuration file might be corrupted, you must delete this file and restart Multisim, this should reset your user interface configuration.
If you have version 9 or prior, it should be:
C:\Program Files\Electronics Workbench\EWB9\Multisim Users\<username>.ewcfg
If you have version 10 or higher, it should be:
C:\Documents and Settings\<username>\Application Data\National Instruments\Circuit Design Suite\10.0\config\standard_ms_uni.ewcfg
If you repair or reinstall the software, the installer does not modified your user config files and your user/corporate databases. That might explain why reinstalling did not worked.
Give this a try and let us know.
Nestor
(4,036 Views)
Thank you very much. That seems to have done the trick.
Howard
(4,020 Views)
