10-13-2009 12:53 PM
I have failed to find a "reply" button anywhere so am posting a new message with my original question and reply.
Hello Multisim calculates wrongly the input impedance of a common emitter stage - judging from the voltage drop on the base resistor network it appears it assumes a
hfe of about 10, when the real value is over 500. I used the 2N2222A as a model, and the error is there on multiple transistors with hfes many multiples of 10. Could you please let me know what I am witnessing here? Thanks Akis
please post your circuit Thanks Max National Instruments EWB Group
10-14-2009 06:57 AM
Hi Akis,
Thank you for contacting National Instruments. I have attached a graphic of the location of the reply button. If you are signed in, you should find this button at the top of the most recent message on the forum thread.
I have also copied your code onto the original forum so that we are all working from the same forum post. If you can't find the reply button, try deleting your cookies and temporary internet files.Also, if you can provide details of the internet browser and operating system you are running that will help if this is still an issue.
Please reply to the original message.
Many thanks,
10-15-2009 07:56 AM
I have now found the "button" based on your fantastic help. I did not expect it to be there, I was expecting it to be like the "Post" and "Cancel" buttons present on this web-form (and most other forum web sites too).
