Multisim and Ultiboard
multisim
I cannot find the 74193  IC in multisim......can anyone help?
(9,186 Views)
It's under 74F, 74HC, 74STD and 74LS.
(9,181 Views)
 I rechecked under the listing you mentioned, and still do not see it.
I have the followng software:
Multisim V.11.0.2 (11.0.775)
database version 11.0.b
Under the TTL listings of devices, it does not show 74F or 74HC.
The listing only shows: 74STD, 74STD_IC, 74LS, 74LS_IC,  and the 74193 is not listed in any of these.  is there an update that I'm missing, or has it been removed in V. 11?
(9,155 Views)
What's your Multisim Edition (Student, Education, Base, Full, Power Pro)? You can find this information at Help>>About Multisim.
Fernando D.
(9,151 Views)
I am using the Student version 11 of Multisim.
(9,146 Views)
The 74193 is not available in the Student Edition. However, I created a custom component for you. Download the attached file, open it in Multisim and copy a paste the component in your design. Please note that you will not be able to save this component to your User Database.
Hope this helps.
Fernando D.
(9,132 Views)
I downloaded the file, and it works great!  thanks a lot!!!
(9,111 Views)
