Multisim and Ultiboard
bcd to 7 segment problem
Hi guys, I just wanna ask how do I make this circuit work? I cant seem to make the 7 segment work and I can see no errors in my connections. Or do I?
http://www.eleccircuit.com/random-number-with-led-1-digit/
(7,015 Views)
The circuit requires a commom anode display.
(7,001 Views)
Hi, thanks for the help. I tried replacing the display with a common cathode but still no luck. Any other ideas?
(6,995 Views)
Check out the attached. The display must be common ANODE.
(6,993 Views)
any one could help me? what's wrong with this circuit?
(6,832 Views)
Hi Ncha,
Your 7 segment LEDS are not connected correctly, if you move the LEDs you will see the problem.
Tien P.
(6,812 Views)
