Multisim and Ultiboard
Connecting pads true a via in a footprint design
Hi there,
I'm making a footprint for this http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=J502-ND component.
Now I need to connect the pads of the GND pin's (on bottom and top) together true a via.
But I can't add a via in the footprint edit mode because there are no layers to select. Or maybe there is another way?
Anyone's answer is gratefully appreciated.
Jaip
(5,438 Views)
Hi Jaip,
You should place a via when you are in the main work area instead of the footprint edit mode, select Place>>Via.  Drop a via where you want then you can double-click the via then select the 'Via' tab, check the assume net then assign it to ground
Tien P.
(5,421 Views)
Hi Tien P,
Thanks for the reply! That is indeed a good solution..
Now I've done it another way (kept trying while waiting for response's) , but not sure if it's going to work properly.
I used normal TH pads, but with custom shape (made a rectangular). De custom shape I placed with the zero-marker (x:0 and y:0) in the middle of the pad.
So when a whole is made, its in the center of the pad, acting as a via... Is this correct?
Jaip
(5,412 Views)
Using a TH pad instead of a SMT should work.  The good thing about this method is you don't have to manually assign a net to the pad, as long as the pad connected to ground in Multisim, the pad will automatically associate with ground.
Tien P.
(5,391 Views)
