Multisim and Ultiboard
multisim
Thanks for reply Jeff but the attachment is just an image file ( .png), it is not a schematic.
Navid
Message 21 of 25
(3,006 Views)
Hi Navid,
It is actually a Multisim snippet file, this uses the PNG extension. These can be dragged and dropped into Multisim and are a great way to share components or circuit snippets.
I forgot which version you were using and accidentally attached the 14.0 version though. Here is a file that will work with Multisim 13.0.
As mentioned above, just drag the file into Multisim or use the File>Snippets>Open snippet file... option.
Jeff
Message 22 of 25
(2,997 Views)
Thanks Jeff. I simulated the circuit for inverting unity gain for u1 ( schematic attached here), and the simulation results are again garbage same as what I had before( output saturates for 1Khz 20mv input signal). I checked with Apex and they said the model is working in other simulator like LT Spice. I am not sure what is wrong here.
Navid
Message 23 of 25
(2,990 Views)
Hi Jeff,
By looking at Spice netlist generated by Multisim, I see that your component connections are not right as I guessed. I have attached a test  circuit schematic with your PA96 you gave me today. For example, I see RL in spice netlist is between nodes 1 and u1_out where it should be between 1(u1_out) and 2. Or, Cc is between 3 and 5 where it should be between 7 and 8. Please help.
Message 24 of 25
(2,973 Views)
The connections are correct, please see below.
In the netlist, the numbers next to Cc, for example, refer to the net connections:
*## Multisim Component Cc1 ##*
cCc1 3 5 1.5e-010
The means that Cc1 is connected between nets 3 and 5.
On the connection for PA96, we see the following:
*## Multisim Component U1 ##*
xU1 0 2 1 u1_out VCC VEE 5 3 PA96_3__APAMP__1
Here you can see that that nets 3 and 5 are connected to the final two nodes on U1.
From the .subckt declarion for U1, you can see how these nodes are mapped:
* REVISION 1 FEB 15 2007 INITIAL RELEASE
* SYMPOL PA85
* BEGIN MODEL PA96_3
* PINOUT ORDER +IN -IN CL OUT +V -V COMP COMP
* PINOUT ORDER    4    5   2      1      3   6       7         8
* NOTE THAT THIS MODEL DOES NOT PERFORM THE
* BANDWIDTH FALLOFF AT LOWER +SUPPLY VOLTAGE
* AS SHOWN IN THE DATA SHEET
.SUBCKT PA96_3__APAMP__1 4 5 2 1 3 6 7 8
The order on the .subckt line corresponds to the order seen above on the xU1 line. The final two nodes here are labeled 7 and 8, which we can see from the comment map to the two COMP pins.
Message 25 of 25
(2,969 Views)
