02-10-2008 11:47 AM
02-10-2008 03:11 PM
I f you can load Multisim under this situation goto OPTIONS>GLOBAL PREFERENCES>PATHS and then under Database Files enter the foloowing:
Master Database: C:\Program Files\National Instruments\Circuit Design Suite 10.0\database\MSComp_S.prd
Corporate Database: C:\Program Files\National Instruments\Circuit Design Suite 10.0\database\CPComp_S.prj
User Database: C:\Documents and Settings\Owner\Application Data\National Instruments\Circuit Design Suite\10.0\database\UsrComp_S_Owner.usr
If you can't load Multisim then try going to C:\Documents and Settings\Owner\Application Data\National Instruments\Circuit Design Suite\10.0\config and try deleting all the files there. The next time you start Multism it will rebuild the config files. I am not sure whether or not this will resore the pointers to the database, but it should. This last procedure should only be used only if the first procedure can't be performed.
I hope this helps. Let me know if it works.
02-10-2008 10:25 PM
02-11-2008 08:16 PM
Well, at least I got it half right. I wasn't sure about the last portion of my post. I am glad you straightened me out on this because I didn't know this about the registry. I usually don't like messing around in the registry because you can mess up more than you fix.
Is there any way in the futrue to have these somewhere else besides the registry? There are a lot of users that may not be familiar with how to edit the registry or (like myself) don't like to fiddle with it.
Thanks Garret. I really appreciate your help with this
02-11-2008 11:05 PM
02-11-2008 11:06 PM
